mr__ed's avatar
mr__ed
Crazy Task Bar
Something strange happened a few minuted ago. My task bar has always been in a horizontal position at the bottom of the screen. All of a sudden it wound up in a vertical position at the right side of the screen. I don't recall doing anything to cause this. How can I restore the task bar to the screen's bottom as before? Thanks in advance.
Equipment: Toshiba Satellite laptop running XP-3.
  • Drag and drop is the easiest method. Or you can right on an open area of the Taskbar, select Properties and under "Taskbar location on screen:", select "bottom." You may also want to checkmark "Lock the taskbar" and click OK, so it won't wonder off again. :)
  • Sometimes you can right-click I(or maybe LEFT click) on the vertical taskbar,
    and holding down the mouse button, 'drag' it to the bottom
    of the screen so that it becomes horizontal.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 27, 2025
