jrs1871's avatar
jrs1871
Direct TV dish question
Well after spending another week in a campground where there was little off air TV available, we have determined that we will be taking our Direct TV with us.
We can take the SD receiver from the family room without much problem. However, we don't want to take down the dish each time. We have an extra round dish, with a single LNB, that we used with our old receiver. But when we switched service so that we could get local channels, we got an eliptical dish with three LNBs. I realize that we won't get local channels when we are on the road but will the round dish with the single LNB work with the SD receiver? Or do we need to find an eliptical dish like is hooked up at the house now.
I looked at the Direct TV website but couldn't get an answer. I'm sure for a price that a technician would come out an get us fixed up. But I'd rather do it myself if possible.
  • I just went through this recently. I upgraded from a SD receiver to an HD receiver and wanted to connect using a single LNB, 18" dish.
    Here's what I had to do (beyond the tripod I had to make)
    Go into the SD Receiver, Setup.
    Go into satellite
    Set Dish type to 01 18" Round
    Set Switch Type to MultiSwitch (NOT SWM!!!!)
    Since you already have a SD receiver, you don't need to change you display to "Display SD Channels" (if you were using an HD box, as I am, I had to make this change.
    Some Explanations for you.
    Satellite type, that's pretty much self explanatory
    Switch Type - Multi Switch tells the Receiver to put voltage on the coax to power the LNB and amplify the signal. If you choose SWM, it requires external power to put power on the coax and drive the amplifier (LNB).
    As to setting up the satellite, I created a tripod, that is disassemble - if you want pictures, send me your email and I'll send them directly to you. It's made out of 1-1/4 or 1-1/2" PVC pipe. I put some adjustments on the three legs to level it.
    I carry a compass (7.00 at a sporting goods store) and a small level and I can usually get the signal in about 10 minutes or so. If you need instructions, please ask, and I'll be glad to share my knowledge.
    I've been to your movie and struggled through what you're going to attempt.
    Most important thing you can do:
    Use your SD box at home on your home network - then setup your 18" dish at home, using the same box until you get it working. At least that way, you'll be sure it works when you're on the road (assuming you have a clear line of site for the satellite).
    Take care,
    Josh
  • Your dish will work fine, but you will need to repeat the Satellite Setup portion of the receiver menu. At home the antenna settings are going to be something like Slimline-5 or Slimline-3 and the Switch Type could be either Multiswitch or SWM depending on how long ago your installation was done.
    In order to use your portable dish, the antenna type has to be 18" round and the switch type will be Multiswitch. When you return home the receiver will need to be reset to the home settings, whatever they were.
  • yes, should work with no problem. when we changed our service (no longer needed 3 LNB's) we went back to our old dish for travel.
  • That should work just fine. Local stations are usually available up to about 150 mile radius of your home zip code. So considerthat in your antenna choice. Also be sure to get a good tripod and enough quality coax to allow you to place the antenna where it has a clear view of the southern sky
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
