- CA_TravelerExplorer III
enblethen wrote:
I got DTV all the way to Fairbanks, Alaska.
We were unable to pick up Direct TV more then 50 miles north of border. - GordonThreeExplorerYou might want to read your contract with AT&T, terms of service, section 1 subsection N.
- We were unable to pick up Direct TV more then 50 miles north of border.
- 2oldmanExplorer IIHow do you aim your dish?
- accsysExplorerWe have used Dishpointer for years. Just be sure to select the particular satellite you want and use the magnetic azimuth not true. We have received DTV reception in both of those parks. It's just a little more difficult getting a clear shot to the satellite due to the low elevation settings - less than 30°
- IvylogExplorer IIINeed to know which dish you are using. If your dish is a round 18" I doubt you will get a useable signal in Banff, much less in Jasper.
- donn0128Explorer IIYou probably wont fiend any for CA. What you can do is pick the nearest USA zip code and start there. Depending on how far north you are, you will likely have to drop the elevation some. Even in southern Canada the elevation is going to be pretty flat.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Aug 31, 2025
