Crodad's avatar
Crodad
DirecTV 101 satellite
I received an email from
DirecTV informing me that I will be losing my local channels on my SD receivers. Which is no problem for me, since my King Quest locks in on the 101.
What I'm wondering about is, what will be on the 101? will it stay the same or will my SD access be limited or eliminated?
  • Bill.Satellite wrote:
    Not boat anchors (other than I think they have been boat anchors for many years) but they will still work. You just need an adapter to take the receivers HDMI output back to coax and you will have down converted to analog that the TV will be able to see.
    We have a Genie and a mini-Genie - they have both HDMI and composite outputs so we're good for now! Buying new TVs is not in the budget currently!
  • ChuckSteed wrote:
    One item to be aware of is if you update your home to the “latest version” of Genie you will not be able to have other type receivers on the same account... you will be forced to create a separate account
    We have a Genie in the living room, and a mini-genie in the den. When we're in the RV both receivers go with us...
  • Alan_Hepburn wrote:
    with the demise of the SD signal from DirecTV will these TV sets become boat anchors?
    If you want to watch HD then yes.
    I just tested it in my den - I've got a mini-genie connected to an old SD television, and the receiver is set to only show SD channels. I changed the setting so that HD channels are showing, and tuned to an HD channel - I was able to view the programming, albeit at SD quality. So, that tells me that I can, indeed watch HD - I just can't watch it with HD quality...
    Good spin.
  • Right. He cannot watch HD. He can watch channels broadcast in HD downgraded to SD quality.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
