buc1980's avatar
buc1980
Directv slimline SWM
I got directv slimline SWM connect to one TV(living room)How I connect the bedroom TV to the dish.The dish have only one cable coming out.The receiver I got is H25.
  • The SWM LNB has 4 coax connections. Take the LNB off the dish bracket and install a second coax.
    ***ON EDIT*** This LNB will not work with a H25 receiver. I use it with 2 - H24 receivers and 2 - SD receivers. -Tom
    -Tom
  • I put the splitter where the outside cable entered the LR entertainment center. There is a cable there also that goes to the BR and to the Basement. I put a short cable from the splitter to each and I have a receiver in each place.
  • I got 2 receivers but I don't know where can I install the spliter.
  • If you only have one receiver then you need to run a new HDMI cable from that receiver to the bedroom (through an HDMI splitter) for HD programming there. You will have to watch the same channel on both TV's but it will work. You should also get an RF remote and the RF update for the H25.
    If you want to be able to watch 2 different channels simultaneously then you will need one receiver at each TV. To accomplish this you will need to add the DirecTV SWM splitter into your current coax setup and run that new cable to the second TV location.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,801 PostsLatest Activity: Jul 05, 2025
