DD716TED's avatar
DD716TED
Directv Standard Def
If I take a Directv H-21 HD receiver from home to tailgate with my Winegard Carrout antenna will I need to use the B Band converter? I fully understand that it will be SD only but the receiver will do that..
  • Select 18 inch round dish during setup and as stated, NO B band converters.
    I used to set up a favorites list that was for the SD channels when traveling.
    No! You will need to go into the receiver setup and allow the receiver to show the SD channels which are, by default, hidden when you are at home. You want to be able to view channel 231 Food but not channel 231 FoodHD.
  • I use a Winegard Carryout with HR-21 and HR-24 receivers and do not use the B Band Converter. In fact it will not work with the B Band Converter.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 27, 2025
