Kenc_AL's avatar
Kenc_AL
Dish 1000.2
After third try in trees last night I have low signal strength as follows (110W - 20; 119W – 24; 129W – 0) I do not have a smart phone – thus not their application. I am trying to shoot through hole in trees. I use web site - www.dishpointer.com to get information which is Elevation 37.6; Skew 129.4 and Azimuth 233. My current location in zip 35160 is near GPS coordinates N33 27.164 W86 08.053. I normally cover 110 & 129 with foil and then tweak 119 but that was best I could get.
The issue is 129 I have zero signal which means virtually no HD nor the locals. Also, low signal on both 110 & 119 which means will loose signal in rain coming this Thursday.
Questions for you guru’s
1) What is the actual magnetic Azimuth from my location for the 129W?
2) 2) At what elevation are the three satellites actually in the sky? Not the dish set-up elevation but exactly where is the signal coming in?
Trying to figure out which way to try and move around in hole to get better reception. Check back here tonight @ 5. Someone out there will have good information!
  • Kenc_AL wrote:
    Thanks for your comments.
    No one addressed addressed the azmith elevation question on 129. I'm not sure where it is.
    According to dish pointer it is- Azimuth (true): 229.6°
    True = magnetic, but you don't normally use that when pointing your dish.
    233 is what you need to use.
  • Yes - I understand and agree that 233 is where you point the dish. Question is what is the actual location of the 129W bird?
    From my current location N33 27.164 W86 08.053:
    110W is Elevation 43.4 Azimuth 218.8
    119W is Elevation 37.6 Azimuth 229.5
    and the 129W bird is where?
    And where do you find that information?
    I've never tried to aim each sat. I've used DISH's published numbers (1000.2 Install Guide (PDF)) with great success.
    For your ZIP of 35160 that's 228 azimuth, 37 elevation, and 128 skew.
    A couple of questions:
    - Have you checked your tripod level?
    - What are you using to point the dish? Compass?
    - What are you using to measure signal strength?
  • mikestock wrote:
    The 1000.2 is a really good smaller dish to convert to DirecTV, replacing the enormous Slimline dish. That's what I have used for years for my RV setup with SL 3 horn, receiving HD channels. Whatever you do, don't discard the 1000.2 dish.
    This is how I used mine.
    Mike, do you have details to make the 1000.2 work with SL3, like height or length to lnb? also do you think it would work with SL5 lnb?
    Thanks Wes
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
