rexmitchell
Feb 24, 2020Explorer
Does your trailer have a dedicated satellite jack on the outside or are you running it through the cable coax? If you aren’t on a dedicated satellite coax this could be the problem. Well, the problem for me was on the inside where the antenna/cable meet behind the outlet and merge into one coax to connect the TV. I had to disconnect the antenna wire and directly wire the cable inlet to the coax. That solved my problem. The splitter can cause issues with satellite signal.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 23, 2026
