jorbill2or
Feb 24, 2020Explorer II
Also you are now running power through the coax. ( which of course was your goal) While it may have worked just passing the video on the old setup the addition of Power has obviously caused a problem. Check all connections , like the one behind the sat “in Jack“ you plugging into on the side of the rv no shorts etc and insure it’s a direct run to the tuner box from there. Too long a cable 50 ft total including the interior run is std but I’ve seen it work with longer , bad connections, poor quality coax all possible.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 23, 2026
