- Bill_SatelliteExplorer IIYou have that right. The domes do still work with DirecTV but only in SD. The older domes will get HD with Dish but most of them can no longer lock onto the Dish satellites due to changes Dish made to their broadcast signal. So......IF your antenna will lock onto the Dish satellites (highly questionable) then you will be able to get HD. If it cannot, you will get nothing at all.
- siggyd777ExplorerWell, the dome is working fine with an H24 & DirecTV,but I only get
SD. But I like to know if I can get HD with Dish . I do not need the In-Motion. I guess ,I need a good friend with a Wally receiver to make some tests with the DIP switches set for DISH.
Thanks for all replies.
Siggy - Bill_SatelliteExplorer II
siggyd777 wrote:
Can I get HD reception using a new WALLY receiver and my RTT-12B-Sdi
in motion dome ?
Thanks for your replies, Siggy
YES! That is if the dome is working! It might not be able to lock onto the Dish satellites (3 of them) due to the age of the antenna and changes Dish make to their broadcast signal. - lryrob9301ExplorerMaybe, can you receive DISH Network now with this dome, if yes then you can receive DISH HD with a Wally. If no or you are not sure read the attached.
DISH Network 8PSK Transition
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
