hawkpat
Aug 03, 2015Explorer
Bill- I have a similar problem that has only recently arisen. Used our taigator for two seasons without a problem while connected to the satellite input in the convenience center. This season several channels would not come up or only come up in SD.
Hooked up through window direct to receiver and works flawlessly. So I took faceplate off convenience center and found the internal connection was a bit loose. Also checked faceplate in coach but it was tight. Thought the loose connection in CC would fix but it did not.
Hooked up again direct to receiver and works perfect again. Wife doesn't like to look at wire going through window.
What puzzles me is why did it work through convenience center for two years and now it won't? I have a 50 ft rg6 cord on tailgater. Would a shorter cable help?
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
