SDM
Mar 17, 2017Explorer
Dish tripod
Going to use Direct tv dish. Is a high quality tripod worth the money? Look at one on TV4RV. Is pricey but looks good.
Bigbird65 wrote:
I previously bought a Slimline system system that just didn't work right. The signal strengths were way down. Lots of trial and error testing including replacing the LNB. Others who bought this system complained about the exact same thing. Nothing helped. I finally determined that the shape of the reflector or arm geometry was wrong. I bought the current system and couldn't be happier. It is a lot more than just changing out the reflector mechanically. The LNB, arm, and mounting assembly must be exactly matched to the reflector or it just won't work. Trust what I am saying. Been there, done that. Best of luck to you HTElectrical.
Ivylog wrote:
Yes a SL3 will bolt on the dish above. There may be a notch on the SL3 that requires spreading the U shaped mounting apart slightly.
HTElectrical wrote:I shoot the 101 to > 90, usually 93. The others will be in the 70+ range, highest around 85. That works.
what kind of signal strength #'s are you getting on the 3 sats?
