klr650goldwing's avatar
Dec 22, 2019
Dish TV
We bought a used 5er that had a Winegard Traveler antenna system that was set up as a Direct TV system. We want to change it to a Dish system. To do so, as we understand it, we need to change the dish feed arm which will change the system from Direct TV to Dish. That is about $255.00. Or we could go with the Dish Playmaker Bundle for $299.00. The Traveler is mounted on the 5er roof whereas the Playmaker just sits on the ground and can be moved to avoid trees etc. that may be in the way for the satellite signal. It seems to me this remote location would also encourage the theft of the unit. What we'd like to know is, which of these two systems do you all like better? What are some pros and cons that you have experienced? And any other thoughts that you veterans may have.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 06, 2026
