I use a Dish 1000.4 that I've modified for easier setup and aiming. As you can see in the photo below, I replaced most of the assembly and adjustment nuts with large or standard wing nuts, making it a no tools needed setup.
I also carry both eastern and western arc LNBF's with me for increased aiming and programming selection opportunities.
For a tripod, I use a low cost roof mount tripod that I've modified for easy setup and leveling, using common hardware store items. The pictures below show the mods.
I'm currently using a VIP211k in the coach, but I have a Hopper and Joey running in our cottage that will be moving to the coach eventually. For your Hopper, you'll need a Dish Solo Node connected to two of the LNBF ports, either at the dish or by running two cables into your RV. If you install the Solo Node at the dish, then you'll only need a single RG6 run into the RV, with a Dish "Tap" on the inside to feed the Hopper. The unused client ports on the Solo Node and Tap should be fitted with 75 ohm terminators.
I hope that's enough info to get you started, but ask away if you have any questions.
