TomG2
Dec 07, 2014Explorer
Disposing of XP Netbook
Someone might get some good our of a working netbook, but obviously I want to remove any personal information. It has no CD/DVD drive. Is there a formatting option which will still boot up?
BruceMc wrote:
If you want to ensure you delete all your personal info, pull the hard drive and smash it with a sledge or drill hole through it. That's the only way to guarantee removing your data.
Then recycle the laptop, or donate ( http://www.computerswithcauses.org/laptop-donation.htm, for example) it to a group that will install a new HD & will load their desired OS.
Chris Bryant wrote:Most netbooks have a standard spinning disk type hard drive. Netbooks have been pretty much replaced by tablets and ultrabooks. I suspect that a computer running Windows XP will be old enough that solid state drives were quite rare.
Netbooks use solid state drives, which are easier to erase securely. If you can boot off a usb drive, I would use DBAN, alomg with installing Lubuntu.
MrWizard wrote:
YES..for yourself
he wants to clean it..then give it away (donate)
NOT install a new OS..somebody else might not be able to use
Tom_M wrote:Chris Bryant wrote:Most netbooks have a standard spinning disk type hard drive. Netbooks have been pretty much replaced by tablets and ultrabooks. I suspect that a computer running Windows XP will be old enough that solid state drives were quite rare.
TomG2 wrote:
The netbook in question is a Acer Aspire One, which has a conventional hard disk drive.
