Rover_Bill
Dec 28, 2020Explorer II
Before you empty your wallet on OTA antennas, see what signals/stations can be received in your specific camping location. Goto AntennaWeb or ANTOP and enter the address where you will be camping. The lists will tell you the signal strength and direction to point your antenna. An omnidirectional antenna will pickup nearby strong stations without pointing. A directional antenna is required for moderate stations and must be pointed directly at those towers. Weak stations require a very big antenna mounted high up and pointed directly at those towers.
If you do purchase your own antenna, be sure it comes with an RG6 cable for best reception. Do not use an RG59 cable.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
