trailernovice's avatar
Dec 28, 2020
does a detached over-the-air television antenna help?
12/28/20
Our trailer has the new type of roof television antenna...stays in place, as opposed to the older 'crank it up and down / turn it to point toward wherever signal is best' type
Even with that, sometimes beyond signal range for over-the-air broadcast channels
Came across a tripod-mounted flying-saucer shaped antenna described as: KING OmniGo Portable Omnidirectional Over-The-Air HDTV Antenna, Black...it would sit on the ground, and connect through the 'cable in' outlet on the outside of the trailer
Would this be any better at picking up signals that the factory roof-mounted antenna we already have does?
(not interested in a satellite solution...we're occasional weekenders, and our trailer isn't the type for long-term television watching)
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    The not always a joke about Omni Directional Antennas is "They work equally bad in all directions"
    For RV use I would recommend scrap the omni on the roof and put in a Winegard Sensar IV with the optional Sensar Pro Wall plate... This is one you crank up and point.
    or you can get any number of fairly good pole mounted... Put 'em up 20 or 30 feet on top of a flag pole and again a directional antenna is your best choice.. that flag pole can be a touch costly though
    But a high gain antenna at height can't be beat.
  • Omni on any antenna means a lousy range in all directions but if your close it’s easy ... no pointing, which to some is “better” . You can get better distance reception with a directional like the winegard batwing with the uhf add on but you will have to get up and point the antenna .. sometimes at different places in the same location depending on where the transmitters are. You can get an app to figure out where that is . Secondly unobstructed height and size is king ! If your antenna is blocked by say , by the air conditioning... no joy.
  • The common Winegard Sensar crankup antennas are still the leader in RV OTA antennas. Nearly any directional antenna will beat an omni-directional antenna, but in nearly all cases height is might with antennas regardless of design.
  • Not any better sitting on tripod. Elevated may help
  • Height is usually helpful. The King would be lower than what you have IMO. And you must set it up and take it down.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Feb 27, 2026
