Gundog's avatar
Gundog
Explorer II
Oct 19, 2020
Dome Satellite is it capable of getting service??
I have a 2005 Fleetwood expedition with a satellite dish on it we have never used. Will this thing work if I get a service? What do I need to check? I am switching to one of the satellite companies from Comcast in my home and would like to get some TV service when we travel. What are my options?
The satellite is a TracVision LF/SF I don't seem to have a reciever but there is a switch box.
When I bought this MH it had some old school Panasonic TV's and a entertainment center with a VHS and a surround sound system. I removed the old TV's and installed 2 new smart TV's with a new entertainment surround sound system that has blue ray and FM stereo.
I did not try and connect the TV's to any of the old cables so they only work with the blue ray players. The bedroom TV has it's own blue ray player.
There is a switch box that allowed switching to each TV and is marked SAT & VHS I will try and post a picture of that I am guessing it won't work with the newer TV's.
  • Trees? Yup they block sat signals, this is at my daughters in Redmond for DTV. Also note the lower 32 degree elevation for the PNW. While tools help find the satelites it was complete luck that I parked in the only very limited area with reception.
  • The 2005 TracVision is so out of date that it is not worth the brain damage. The VHS should be a clue. Your coax is not up to date either. Take a deep breath an do lots of research and or wait for the real techies here to comment.
  • You will not get a signal parked under a tree but it you are on a budget than mounting a home style antenna on a tripod is a great choice. You get the exact same home service as a much lower price and you can run a long coax cable to located the antenna in a clear spot while the RV remains under the trees.
    It takes a bit of time to learn to manually point the antenna at each new location but 3-5 times setting it all up will make it very understandable. There are a number of apps available for your phone that can give you the correct direction to point the antenna and the correct elevation, azimuth and skew required for proper reception. Plan on spending $200+ for a really good antenna/tripod setup.
  • I see some people in the camp grounds with portable units on a stand is that a better option than hard mounting them to the roof like my old one? I camp in the Pacific Northwest where many of the camp spots have a lot of big trees so I am wondering if you might not get a signal parked under a big tree?
  • I tried calling both Dish & Direct TV and never could find anyone who knew anything. I don't think TV is worth the $1800 for a new dish holy cow I wasn't expecting that.
    I did another search for RV satellites on ebay and I am seeing some units for much less $150 to $500 that is a little more doable.
  • Personally, I would not bother with it. Even if it does work, it will only work with DirecTV and you will not be able to receive ANY programming in HD via the dome. The antenna is too old to work with DISH. If you are replacing your equipment at home, personally, I would buy a Winegard Trav'ler (I prefer DirecTV for service but both services are very good). If you buy a Trav'ler for DTV and change your mind in the future you can swap it over to work with DISH. However, if you buy the DISH version there is no conversion option to go to DirecTV.
    No, you can't use it while driving down the road but when you are parked and push the button to let it lock onto the satellites you will get the EXACT same service that you would get if you were sitting at home (other than Network programming, the one possible DISH advantage).
    Just move your receiver from the house to the RV and take off!
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Aug 21, 2025
