pasusan's avatar
pasusan
Don't want to use wireless - Update - all OK
I've been getting home computers (and networks) to work since 1994... But - I've got something new that I thought someone here might be able to help with. Apparently I haven't come up with the correct search terms for Google...
Just got a new desktop that has integrated wireless. I've got wires. And wireless. I definitely want the new desktop to connect to the network and internet with the wired ethernet.
Windows 7. The taskbar at the lower right on the screen says: Netgear Internet Access. Netgear is my wireless router. My wired router is D-Link. I'm thinking I'd rather have my internet access with the wired connection.
Anyone know what I should look at and how to turn off my wireless connection in the new computer so it will connect through the wired D-link router?
Yes, the ethernet cable from the D-link router is plugged into the back of the new computer.
Also - I can't use "Homegroup" as I have a Vista and XP machine in the network.
If pictures of the "network and sharing center" info are needed I can provide them.
Thanks for any help.
  • OP here - what's strange is the Windows wireless is off. I'm thinking there is a Dell wireless also?
    But - I think I will try turning off the wireless router (pull the plug) and then turn on the new computer - maybe it will find the wired router.
    dahkota - no it doesn't see it. Will try above step...
  • Go to the Windows Control Panel. Then Network and Sharing Center. Then Change Adaptor Settings. Find your wireless adapter there, right click on it, and turn it off or disable it.
    Then when you reboot with the wired connection plugged in, the computer will find it. And Bob's Your Uncle.
  • It is a desktop, not a laptop.
    Have you looked to see if Windows even sees the D-Link? Go into the Hardware section of the control panel. If it isn't there, try to add it.
  • You can always disconnect from the wireless specific account without turning off your wireless. It really is 6 of one half a dozen of the other.
  • X2 - Check to see that the wireless switch (physical switch) is turned off. The laptop should then revert to the wired connection.
    Craig
  • Generally a laptop will have an external switch to turn the wireless on and off.
    BTC
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
