Bill_Satellite
Sep 23, 2013Explorer II
If I recall correctly, that setup is designed for a car and the interior antenna had to be very close to the phone to operate. That might not be an issue as long as you properly locate the antenna in the area where you think you will most often use the phone. The 3G limitation would be enough reason for me not to buy it but if all you are concerned about is voice then this would not be a problem.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
