greg121's avatar
greg121
DVD player Setup
Went to use DVD player and get nothing on the TV. Worked last time we used it a few weeks back. Don't use the TV often so it's always a challenge moving from one mode to another. Since last DVD viewing had set up for cable so I figure it's far more like to be a configuration issue than a cable coming loose to check which would require minor surgery.
DVD plays via a modulator. Setting I have are modulator on (light verifies) channel 3 (also tried 4) TV switch box set to TV ant, TV itself set to air and channels scanned with modulator on. Returned some channels but not DVD.
Any corrections or ideas before I start surgery?
  • Thanks for all the interest. Yes, modulator is built into the switching box and I've tried TV (which is what I kinda recall using when it last worked, if I watched more often than once a month or so I might be more certain of settings). Anyway, tried several - TV, AV, DVD changing input source as appropriate.
    Jenson has all above inputs plus 2 HDMI. Why in this day and age Winnebago set it up for modulator is beyond me but was OK with til it didn't work
    All cabling in the wall or behind the Entertainment panel where player and switching box are. Looking like I'll have to open it up and see what's connected to what.
  • You also might want to start playing a movie before you rescan for channels.
  • Since doing a scan picks up TV stations it sounds like the antenna is still connected to the TV. Your switch box should have a DVD player button. If all else fails, connect a coax directly from the F connector on the DVD player to the antenna in on the TV and do another scan.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
