wa8yxm
Feb 23, 2015Explorer III
Short answer: The motor does not care, 12 volts or (xx volts) is 12 volts (or xx volts) it needs the proper voltage likewise the motor controller, all it needs is the proper voltage, and of course enough amp hours to haul you about.
The battery CHARGER however,,,, that you will need to upgrade.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
