trailertraveler's avatar
Jun 14, 2021
End of Direct TV SD should I switch to Dish?
Finally got a notice from Direct TV that they will start systematically ending their SD service in July 2021. I am not necessarily looking for all the bells and whistles of multichannel viewing, recording or using more than one TV at a time. I have a wireless repeater that can send the TV signal to the bedroom TV. We currently have the DNS feeds from LA and NYC. Reviewing the program packages, it appears that the Dish On the Go Channel lineup can include ABC, NBC, CBS and Fox out of Denver. Is this accurate?
Direct TV says they will replace my receiver for free. They were not sure about the antenna.
I currently have a portable SD dish (one LNB) which is usually not that hard to setup. How much harder is it to setup the 3 LNB slimline dish? It does not appear that any of the portable automatic antennas work with Direct TV HD.
In my research, it seems that Direct uses satellites at 99, 101 and 103. The Dish western arch is 110, 119, 129 and the eastern arch is 61.5, 72.7, 77. In the 17 years that we have had Direct SD, the 101 Satellite has been relatively easy to lock onto just about anywhere we have been from Montana to the mid-Atlantic states. It is high enough in the sky that the dish does not have to be all that far away from even pretty tall obstructions. Looking at the Dish satellite locations the 119 and 129 look to be pretty low on the horizon and the western arc and eastern arc satellites are spread over a much wider degree range than the Direct satellites. The Tailgator and Playmaker can use the Dish 61.5 satellite in place of the 129, but this greatly increases the spread of the satellites being used. The Pathway X2 can use the Dish eastern arch satellites which seem to be higher in the sky and less spread out. If the automatic dish can not acquire all the satellites. Can channels on the satellites it can acquire be watched?
Any experience on how much if any switching from Direct to Dish affects being able to actually get a satellite signal without always being in a wide open lot or the desert would be greatly appreciated. Also, the automatic dishes all seem to recommend no more than 50' of coax. In some cases with the SD dish we have used up to 300' and still gotten good reception. Any experience/comments on what the real world limit on coax length for the automatic dishes is? What receiver and what antenna are you using?
Thanks for any and all comments.
  • Ivylog's avatar
    Ivylog
    Explorer III
    You do not need the big slimline dish (uses a bigger tripod) to get 99 & 101. A 18 X 20 multi sat dish with a SL3 lnb added will work and fit on your current tripod. Aiming requires you to plumb the pipe mast (perfectly up/down), set the tilt (skew) and elevation for where you are then just rotate.
  • Don’t know what there going to do ether. Was watching NASCAR and a storm moved in causing bad reception. A message popped up asking if I want to change to a lower resolution, I clicked yes and and it went SD
  • We got dish when we first bought our 5er in 2007. Have both a Tailgater and a 1000.2 tripod antenna. Tailgater is convenient in its automatic search, but sometimes had problems finding satellites. 1000.2 tripod was a little harder to aim at first, but soon got to where I could aim it in less time than the Tailgater when thru its several minute long search gyrations.
    Great thing about Dish (in my opinion) is that you can get the major network channels for the nearest city to your location at the time. Means you can get the programs in their normal broadcast time no matter where you are, and you can get the local weather forecast/warnings.
  • Aiming a Slimline dish is harder than the SD dish, but with practice you'll get better at it.
