tko9900's avatar
tko9900
External Hard Drive for Dish 211z
Installed a External Hard Drive for Dish 211z. When I watch recorded programming the audio skips every few seconds. Tried a new hard drive, same problem. Dish tech thinks it's a problem with the receiver although he says the receiver is up to date. Concerned a new receiver won't solve the problem.
Anyone else have this problem? Any ideas?
  • I just installed a Seagate this weekend. I don't have any skipping with my 211z.
    The HD I bought came with a 120v power supply and two cords. One USB and the other a eSATA. I used the USB cord.
    What I don't like is if I unplug the Hd for a day or so and then plug it back in the Dish has to restart, which means it has to recycle through the sat search again. Other than that it's really nice to be able to pause live tv, fast forward or rewind.
    I only have a short amount of time using it this weekend so I'm not totally familiar with it.
  • Dish tech told me to get a Seagate 1 TB. I am hooked up by USB to the receiver with the cable that came in the package. What kind of a hookup would a external power supply look like?
  • what external HD did you use ?
    the USB port might not support the power needed for a USB only drive that gets power from the port, this will reduce read and write speed
    you might need a faster drive that uses less power
    or you can try a drive that uses an external power supply
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Feb 08, 2025
