Goostoff's avatar
Goostoff
flooded tailgater
was watching TV the other night while watching the storms and flash flood warnings when all of the sudden my satellite gives some odd message on the TV and loses complete signal. Figured I better go check it out. When I opened the door I looked out to find the water had made it to the bottom step on the trailer. I took off my shoes and socks and went out to find my tailgater completely submerged. I picked it up and it weighed about 40 pounds. I disconnected the cable and carried it over and sat it on the picnic table to drain. About that time I noticed the water was up to the second step on the neighbors trailer and he had belongings floating away so I went and hammered on his door to wake them , and helped him gather his stuff. Once we got everything under control we just stood there shooting the breeze since we were soaked to the bone anyway.
The next morning when the flood waters had gone down enough that I could get me tailgater on dry ground I took it apart and hooked it up. It will spin all the way around in both directions, and it will also go up and down but it could not find a signal. There was also a little green light flashing 2 times on the circuit board.
I left it sit in the sun with the top off for the day and when we got home on sunday I ran to town and grabbed a bunch of desiccant pouches and tossed them inside and put it back together and sat it on a shelf in the house above the A/C. Gonna leave it till this weekend and try it again to see if it survived or if I need to start tracking down parts.
Anyone have any other ideas for me to try or a lead on parts, and what the blinking light is?
  • Yes, rinse it with fresh water and gently dry it with a hair dryer.
    Like said above electronics are probably toast. Also need to replace your cable.
  • Once flood waters penetrate electronics you can usually kiss them goodby. If you had a chance to rinse the thing out with clean water and then let it dry you stand a chance but the junk in flood waters is just a breeding ground for future failures.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 27, 2025
