720Deere
Mar 27, 2014Explorer
Lockpick
The Lockpick is activated by the phone button on the steering wheel and some functions are on the touch screen. Installation is pretty easy. There are two trim covers on the lower outside parts of the center dash panel. Pop those off and find a small bolt under each one. After removing the bolts, it is as simple as carefully pulling the dash panel loose from the bottom and unplugging some wiring harnesses to allow complete removal. There are 4 screws/bolts that hold the head unit in the dash. Once you pull the head unit, the rest is just unplugging harnesses and plugging the Lockpick inline. Maybe a 1 hour job the first time, but only takes me about 15 minutes now. The hardest part is getting the darn Lockpick module stashed in the dash. There isn't much room in there.
As previously stated, if you had to go to the dealer for warranty work related to Sync or the head unit, simply remove the Lockpick prior to your visit. There are no stored codes or other evidence that it was ever there.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 19, 2026
