anaro's avatar
anaro
Garmin Dezl 560LMT GPS
I know many have discussed how much they like the Garmin over the magellan and rand mcnally in the other threads. Just wondering if anyone has used the cheaper truckers version, the Garmin dezl 560LMT. My old Garmin Nuvi served me well but is in need of replacement. I was thinking of going with something I can program height into for my fiver. Is it a waste of money? Should I go back to a regular GPS? Through researching, I know to stay away from the Magellan GPS. Thanks
  • Lantley wrote:
    anaro wrote:
    Niaswagn- interesting thought. My defective gps is related to dropping it but I can try.
    Lantley- I usually have DH have a back up set on Google maps ready on his phone when travelling. If I'm going somewhere really unfamiliar I have been known to print out mapquest and Google directions before going on case of loss of satellite or something crazy happens. I have been down a dirt road with a gps before, fortunately not with a trailer behind me
    Then you get it. The truckers/RV model GPS will route you to avoid small streets, tight tuns and low clearances. I do believe they are worth the extra. But keep in mind they may occasionally take you the long way. If anything I sometimes find the RV routing to be too cautious. It will take the long way to avoid smaller roads. In the end better safe than sorry
    IMO that is the single biggest negative with the 760 and while I can't be 100% positive I think when you are in the RV mode it uses all the truck routes around major metro areas as a default which is most often not needed when towing RVs.
    Two features I do like a lot is the "rest area" and "truck stop" listings in the unit.
    Larry
  • I have the Dezl 760 and overall like it very much. That said, it has it's limits and you should be careful with what it tells you. One time in Maine it took me on a VERY problematic route to avoid a hazard. Luckily I was not towing at the time (even though it was left in RV mode), or I never would have made it through the narrow residential streets it sent me on.
    It also tried to send me 200 miles out of the way to avoid a tunnel hazard on the Oregon coast, which I ignored. Turns out the edge of the tunnel was below minimum, but the peak of the arch was 4 feet higher. I was in terror as it kept warning me about the upcoming low clearance, but I kept seeing units taller than mine coming the other way....
    There are a lot of places where it tells me that hazard data does not exist, so I end up having to cross my fingers there is nothing ahead that will cause problems, but they are obvious areas where there is no concern anyway.
    I also have the Rand-McNally version on my iPad, and can't say in the above respects it is any better. I find operating the Dezl to be much better. Love the "lane assist" feature that tells you ahead of time which lane to get in to. Saved me in Chicago multiple times!
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
