pasusan's avatar
pasusan
Garmin GPS keeps taking us off main route
I'm not sure if this just started with the latest update or if it has always done it with certain roads. We just got the new GPS (Nuvi 67) at the beginning of the year so we could add a backup camera to it.
We traveled for thousands of miles down to Mississippi & Georgia - stopped at lots of CGs and sites without a problem.
Well, for our fall trip we stayed in PA going across Rt. 6. 6 is a minor highway - yellow on Google Maps. Many times the GPS would try to take us off 6 for what one would think would be a shortcut, but actually wasn't.
Here is one example:
Click For Full-Size Image.
The blue arrows are where the GPS wanted us to go, but when we ignored it and stayed on 6 the time recalculated to 5 minutes less.
Other times it would have saved us a minute (or none) to get off our main route and take a "shortcut".
DH is getting sick of me chiming in with "ignore the GPS"
Anyone familiar with this type of problem? Doesn't Garmin know we'd like to stay on our chosen route?
  • Yes, check the navigation settings. Might also look at your choice of "quickest route" or "shorter distance".
    Also make sure "paved roads" is checked (or it might need to be unchecked)! Otherwise you might end up in a farmers field!
    Good luck!
    Mitch
  • Garmin instructions are terrible. You could get online and read them and they still may not answer your question. (Says 20 years a Garmin owner of more than a few.) Most of the others are no better.
    Try going into the setup and make sure that the things that are checked are what you want. Two that come to mind (I don't have a 67) are "Avoid Highways" and/or "Toll Roads" and then there is the faster time/shortest route choice to mess things up.
    Good luck
    Matt
  • 2oldman wrote:
    Just drive across the river:
    Well - at least yours is the more direct route! :)
  • The most common cause of this is selecting "shortest"(distance) rather than fastest time.
    You also need to check what "avoids" you have set.
    BUT......sometimes it's logic is fractured and there is NO apparent reason for an odd route.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
