ktmrfs wrote:
ol Bombero-JC wrote:
(IMO) OnStar is a bit expensive - unless you feel ya gotta have it.
Even w/o it, you can still have Sirus XM and standard navigation.
(Sirius will cut you a great deal -price- if you let it lapse)
Pos solution for the OP - check out AT&T ZTE Mobley standalone $20 a month unlimited plan. (Purchase the device outright, or free w/2yr contract)
You can either plug it into the OBD port in your vehicle -and- buy/make a 110V converter for your RV/home.
BTW - in either location, *you* can set the delay for length of time it stays on - including "always on".
Threads:
On RV Net
On SKPs
Plus a few more threads if you search.
Also - info on the Howardforums
yes, the onstar wifi is expensive if you don't have an ATT plan. no disagreement.
and IF you have good cell reception, then a stand alone hot spot is less expensive and more convenient option. and the way to go.
But if cell reception is poor with your ATT phone/hotspot, the onstar WIFI has a more powerful amplifier and receiver and better antenna so there are spots where a regular cell phone will give NO signal and onstar phone/wifi has plenty of signal.
Or, if you are like us and have Verizon and don't have coverage, AND are in ATT range, then the onstar wifi is an option.
So, for us it's a good backup. between onstar ATT service and our verizon plan we pretty much get phone/wifi service anyplace it is available. which of course does leave plenty of places we get no cell service.
Fortunately I'm *not* in a poor cell phone reception area.
Nor am I a cyber guru or geek squad member..:B
However, regarding the poor reception.....you might peruse the link to
the SKP forum for lots of antenna discussion to improve same.
Also - apparently the Howardforums have been "onto" the Mobley for much longer than the forums here or on SKPs.
BTW - forget where I saw this - isn't OnStar WiFi via AT&T?
Would seem you should be able to match the OnStar capabilities(?)
And - the reason I purchased outright from Best Buy, was the 14 day return policy. Figured if it didn't perform (at least to my expectations) I could return it.
Best Buy salesperson said they would wave the 15% re-stocking fee if I returned it.
No complaints so far - running 24-7 off 110v...:)
