TenOC's avatar
TenOC
Nomad
Sep 20, 2016
Hard Drive Lost Format and Name
HP xw8600 PC with Windows 7 Ultimate and ESET antivirus all up to date.
I have 3 hard drives in my computer --- C: is the operating system, --- F: (2Tb) is for data and --- V: (3Tb) for for backup using Symantec System Recovery 2013 R2
The last time I checked there was about 500Gb of free space on the V: drive. Today I had a backup failure. After rebooting I find that the V: drive has lost its format and name. Windows Explorer says that I should reformat. This same thing happen about 6 months ago also.
Disk Manager show the V: HD but without any name and 100% free space.
I know I can reformat, but I am more interest in what went wrong.
The 3Tb drive has been working with no problems making daily backups.
Any suggestions?
Could it be that I hit the 2.2Tb limit? Disk Manager show it as a 2794.39 Gb.
  • This can also be caused by a USB controller or HD controller failure which is not allowing WIN to read the drive properly. First, try using a different USB port on the PC. If still reading similar, than most likely the issue is within the drive itself.
    I'm not a big fan of incremental backups as you need the original backup, and all incremental backups to successfully restore. Any one incremental backup which gets corrupted, could potentially cause the restore to fail.
    Differential backups only require the original backup, and the latest differential backup to restore. Only involves 2 files, instead of how many incremental backups were made?
  • Sam Spade wrote:
    wa8yxm wrote:
    I think I'd start by REPLACING the "V" drive
    +1
    And.....you aren't set to do an ENTIRE mirror image backup every time, are you ?? That is an unnecessary waste of time and space.
    I do an incremental backup. Each daily backup is only about 5 to 10Mb
    +1
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I think I'd start by REPLCING the "V" drive
    But first Reformat as instructed, then download a drive test program (The manufacturer's is generally good) and let it run for a while, Use the deep scan and let it run overnight.. Or longer.
    Next: One of the issues with some backup programs is they do not check for space on the target (Backup) drive, so if your back up takes say 2 TB and the Target drive has only 3 TB of space, when you do the NEXT back up it runs over, this is because even if you use "Save with replace" it saves THEN deletes the old, and you do not have the room. Hence.. Crash
    This crash can get into the part of the drive which SHOULD be protected, the part that holds the name and ID. I've seen it happen with smaller drives.
    Suggest a bigger Backup Drive.
  • Chris Bryant wrote:
    Whoever made the drive should have diagnostic software available- I would use it to do a full surface scan. I would also probably replace the drive on general principals, as I suspect the drive is failing.
    It passes the extended test which I think is a surface scan test. I also ran chkdsk /f which found a few error and fixed them. From my Google search it looks like the disk lost the MBR/partition table.
  • Whoever made the drive should have diagnostic software available- I would use it to do a full surface scan. I would also probably replace the drive on general principals, as I suspect the drive is failing.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
