Dave_H_M's avatar
Dave_H_M
Explorer II
Sep 02, 2016
Hardwiring the modum to the Computer?
I have just picked up a modum from the ISP. In the process i also had to have the phone company sent a service person to get the junk running.
In the process the tech showed me that the ethernet card or whatever is not working in the desk top. Tried the lap top and it worked. The desk top is now running on wifi.
The modem has a USB port on it. I am wondering if i can just plug a USB in the back of the modem and the other end into the computer and thus have the modem hardwired to the computer.
  • Your DSL speed is WAY slower than your wireless connection between the desktop and router most likely. The direct wired connection won't gain you any internet speed at all. As already mentioned that USB port on the router is almost certainly to share a printer or external hard drive, and nothing more.
  • Silly, but did you power down and back up?
    Did you look to see if there are any lights where the cable plugs into the computer?
  • If you just got it back from the shop after having W7 put back on I would suspect the shop didn't get all the drivers reinstalled. But a new ethernet card would be super cheap to buy.
    And no, hooking up the modem through the USB will not "hardwire" it to the computer.
    If you're on the fringe of a 3 meg DSL line you likely won't see any speed increase if you use ethernet cable to connect the modem to the computer. A good wireless router should give you throughput speeds way in excess of your 3 meg line speed. That's assuming that you aren't blocking good signal from the router to the computer.
    As far as security, a ethernet cable will be more secure than Wifi of course, but with a good WPA2 password, and WPS disabled you're pretty secure. Six of one, half dozen of the other.
  • Thanks for the quick replies. Forgot to mention that i just got the puter back from the shop to the tune of 175 bucks. Just gdot it back on win7 and working again after the win 10 mess.
    I was told that ethernet was more secure and maybe faster by a little bit. Speed is my killer in that i am on the fringe of a 3 meg DSL which is run out here in the country thru copper wire/cable.
    Gonna give the shop a call and go from there.
  • And for most people, there is no particular advantage to having it hardwired versus wireless anyway.
    But if you are determined to do this, a replacement ethernet card probably can be had for about $20 at any computer store.
  • There is a 99% probability the USB port on the router is for a printer or external hard drive and there is almost no likelihood that it provides a network connection.
  • You didn't specify which cable network bridge (Not a MoDem because it doesn't change data to sound, or sound to data) you have. Is it a bridge/router/Wireless Access Point combination? We don't know what the USB port does on it.
  • No. If you are hard wiring your computer to the modem, you need to use an Eathernet cable. It looks like a telephone jack, but is bigger.
    It's possible your Eathernet card in your computer has died.
  • Bobbo's avatar
    Bobbo
    Explorer III
    Probably not.
    Have you checked to see if the ethernet port has been deactivated?
    You most likely need a new ethernet port on the computer. That should not be hard or expensive. Call the Geek Squad.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Dec 30, 2025
