The Works wrote:
Bill.Winegard wrote:
Did you measure the voltage at the head of the Batwing? If you have 13.5V on the roof with the fans running I would suspect that the power supply is wired to a dirty 12V circuit or the power supply itself needs to be replaced. If you have a way of connecting to a different circuit (or run something directly from a 12V battery/power source you could determine which is at issue.
I measured 13.5 at the antenna right on the coax cable. Some have suggested placing a capacitor from the +12vdc line to ground, do you think this is feasible and what size of cap would be required. I'm thinking about replacing the oem 12vdc power supply with a 120vac to 12vdc converter and running the antenna off the substituted power supply.
Bill..I'm back with the same pixelization issue I've been having since replacing my OEM TV antenna. When I turn on the bathroom fan the TV's, (2) start pixelating to the point where the TV's are unwatchable. I ran a 14 awg wire directly from the RV battery to the wall plate, disconnected the oem +12vdc power source and connected the battery to the antenna +12vdc connection, the results were the same. I substituted the +12 vdc power source with a 120vac to 12vdc converter and again the results were the same. Both the RV battery and ac converter supplied +13.41 volts to the antenna. When the fan is turned on the voltage drops to +13.39 a difference of two hundredths of a volt, I don't think this lower voltage is effecting the operation of the antenna. I reconnected the RV oem +12 source and re-measured the voltage with both the fan on and off and basically I had the same readings with the same voltage drop. I'm starting to think the antenna might be bad? Your thoughts are appreciated.
