troll3193
Aug 07, 2013Explorer
If you are going to do an FM modulator, which I have done several times, go with one that is hard wired into the antenna.. Like this..
http://www.amazon.com/Scosche-FM-MOD02-Universal-Modulator-Satellite/dp/B001QBG614/ref=sr_1_1?ie=UTF8&qid=1375882505&sr=8-1&keywords=fm+modulator
you might need antenna adapter cables depending upon the size of the antenna cable on a range rover
Since you range rover has a remote CD deck, you can probably swap the connection out to an aux input converter, which I have also done in a few vehicles.
http://www.logjamelectronics.com/landroveraux.html
Logjam is really good at helping you identify your head unit and verify compatibility..
Bryan
Bryan
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
