Thunder Mountain wrote:
You don't have to call Dish when you move. Use the chat feature. I have a saved word file that I cut and paste into the chat window. I just have to fill in the new service address.
Yep, Samo-Samo....
I just get the USPS address, copy past into the chat and tell them to change the "Service Address" ONLY...not billing. They will change it otherwise and even after telling them by check a box. You can double check after the chat in your dISH profile.
Chat, once they respond, usually within a minute, it takes about 2 min to make the change, done.....
Stations will change over in about 1-20 min along with program guide..
Chat's the easiest way...
Hope that helps.. they also pick up the locals too.
Happy Trails..
