texasfire's avatar
texasfire
Help with Winegard
We recently bought a Crusader fifth wheel that had the Winegard installed, unfortunately there are no instructions. I tried calling them and sat on hold for 30 minutes, tried emailing them but have gotten no response. The only paperwork we have with the trailer talks about turning the antenna manually from the inside but there is no handle to turn like in our old trailer. Any help would be appreciated.
  • The red light indicates that the amplifier (built in) is not powered. The light will be green when the amp is powered.
    BTW, amplifier not powered is worse (gain wise) than no amplifier at all.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Omnidirectional antennas do not have the crank or knob that the Batwing has.
    They also do not have the range (Senistivity) the Batwing has
    So the reason you can not find the crank and knob.. There isn't any.
  • google is really your friend in the RV world.
    https://winegard.com/air-360-hdtv-antenna/
    at the bottom is link to owners manual
  • According to the paperwork that I do have its an Air 360+ long range omnidirectional HDTV antenna. Brown round plastic bubble on the roof. I also have a small button mounted in a compartment that stays red, if you hold it long enough it will flash but that's about it.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Winegard makes several antennas
    one, well several, are of a design we call "the Batwing antennas" These have ahandle to turn and the Sensar IV is one of if not the best RV OTA antenna
    The ROadstar looks like a flying saucer.. The most common one is an "omin"direcitonal meaning it works equally bad in all directions.
    There is another flying saucer that is direcitonal or so I'm told.. I saw another company's version of it. Never seen the winegard.
    Then there are satellite TV antennas. Again multiple models.
    We really need to know which one you have.
  • winegard what? sat? OTA antenna? motorized? a model name/number would help us.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
