gatorcq
Feb 19, 2018Explorer
Here's the thing. Your winegard does not need to be connected to the Hopper to work.
So, disconnect the cable from the Winegard to your Rv.
Then turn on WG. When it stops, do you * next to the 3 Satellites? If yes then it is locked on. Now connect the Hopper. Do you have a Solo node in line or what? Now you go to system setting ??? Antenna ? Check Switch?
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
