ktmrfs
Feb 05, 2020Explorer III
wnjj wrote:ktmrfs wrote:crcr wrote:
Thanks to all for your helpful responses. Much appreciated!
The file that was sent to me that I am unable to open right now, is an Excel file and has the following suffix after the file name:
.nonp.xlsx
So I tried removing the x from the end, and the file still won't open in my 2010 M-soft Excel. Any suggestions?
Regarding enabling Macros, I searched and found instructions to do that, and I find that Macros are already enabled in my M-soft Office Excel 2010, even though I had never touched those settings before.
If I understand correctly the file name is something like Filename.nonp.xlxs. If this is the case, the likely issue is that the file was named and saved incorrectly. A office file should be Filename.xlxs or filename.docx NOT filename.something.xlxs
until the file is saved correctly office or likely the clones won't open it.
I don't know about that. The extension is always everything after the last '.'
I renamed a file and it still opened ok with 2 dots in the name.
I tried saving a file temp.noop and yes it did save it as a docx file and I was able to open it. So...... the op should have been able to open the file. I suspect the file may be corrupted and office is unable to open it. I've on rare occasion had that issue.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Aug 30, 2026
