Sinnettc's avatar
Sinnettc
How cold is too cold for LCD/flat panel tv?
Temps going back down into the 20's tonight. At what point do I have to worry about the TV in the new to us TT getting damaged from the cold?
  • There is no temperature too low for storage of LCD panels period.
    Don't worry about it.
    There is a common myth out there about this.
  • Guess I won't worry about a measly 19* or 20* F then. :B Thanks
  • From Samsung FAQ web site:
    Samsung LCD TVs can operate safely in rooms or areas in which temperatures range from 50° F to 104° F (10° C to 40° C). Temperatures outside the listed range will negatively affect the operation of your LCD TV.
    Samsung LCD TVs can be stored unused at temperatures ranging from -4° to 113° Fahrenheit (-20° to 45° Centigrade). Storing your LCD TV at temperatures outside this range can damage your TV.
    From Phillips FAQ web site:
    Operating:
    Temperature: 5 to 40 degrees Celsius (41 to 104 degrees Fahrenheit)
    Humidity Levels: 10% to 70% (Non-Condensing)
    Storage:
    Temperature: -15 to 50 degrees Celsius (5 to 122 degrees Fahrenheit)
  • We have never removed our flatpanel tvs and they have been through -25 degree temps with no ill effects noted. Of course we don't ever turn them on unless temps are within manufacturer's operating range specs. Nothing wrong with bringing them inside either as everyone should do what they feel is best for their situation, but most dealers in cold country don't remove every tv from every RV on their lot as it would consume too much time and space.
  • It almost depends on the manufacturer. I know the Jensen TV that I have in my trailer is shockproof and cold proof so I never worry about my own stuff.
    I'd think you'd probably be fine leaving it where it is, no matter what mfg makes your unit. In sub zero temps, the TV is probably fine. I haven't read any horror stories about people losing their TV's on RV.net yet!
    WoodGlue
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 13, 2025
