rockhillmanor's avatar
Oct 17, 2015
How to capture image info when it's mouse over
When I needed a pix to refer to in a post I'd go on line and simply copy the image info.
Now all the websites have switched all their images to mouse over and you can't copy the image link to the pix.
Is there a way to capture these darn things?
  • The snipping tool doesn't always work for mouse-over items - since you have to move the cursor from the mouse over area in order to use the snipping tool.
  • Also for images that require "mouse over" to enlarge, it simply doesn't capture the entire image to simply hit "prnt scrn".
    That is why I said to mouse over it. Otherwise, how do you get the image to enlarge to capture it ?
    I'm not at all familiar with 'mouse over' to enlarge. Where do you find these?
  • I use Print key 2000 and it works on win 7 and win xp but I don't know if it works on win 8 or 10. I think it probably does. All you have to do is dbl click on the print key icon and it takes a picture of the screen. You then can pick what you want to save using the menu at the top. Probably the same as other programs but just wanted to mention its existence.
    Exactly. Just use PrtSc and Paste.
  • Right click on the page and choose view source. You should be able to find the image link there - if you have a working knowledge of HTML.
    I have also used the print screen/ Paint method, and the snip tool.
    If you Google and select images, you can view an image and get it's link.
  • If you're using Firefox, right-click on the image. Click "View Page Info." This will open a new window. Then click the "Media" tab at the top of the new window that has opened. Click through each of the "Address" entries in the list. When you see the image you want to save, click the "Save As" button to save the image to your computer.
    This method works well when the page uses Javascript for the 'onmouse over/onmouse out' functions and the .jpg link is not apparent in the 'view source' info.
  • right click on the image. click properties. in the box that opens up cut and paste the address (URL).
  • If you're using a photo or graphic from another website for discussion purposes, then copyright in most cases is not the issue when protected under fair use doctrine. Though appropriate to properly credit the author. However, fair use does not cover against stealing server bandwidth without permission. Which is what happens when one embeds the photo from the owner's website. Use a separate photo hosting instead.
    To answer the original question, some websites use Javascript to disable right-click in order to block copying URL. A weak solution, as disabling Javascript defeats the ability to do so. However, all major browsers have developer mode, usually the F12 key, which would allow you to determine the URL of the photo. Firefox also has right click on the page to View Page Info. In the Media tab, you can find the photo URL or download in most cases.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
