TechWriter
Apr 28, 2015Explorer
Big Katuna wrote:{tpc} wrote:Big Katuna wrote:
My roof antenna cable is connected to a Winegard Sensar Pro amp then to the TV. I change tv inputs to watch OTA.
My outside cable input runs into the AV area and I use it to run the raw sat signal from my sat dish to my sat rcvr. HDMI to the tv and switch tv inputs to watch sat.
You can add diplexars on both ends if you wanted to still use the cable for cable AND sat but I NEVER connect to cable so I just use it for sat.
So you have successfully used the cable input wiring for the raw sat signal?
Absolutely for years. There is a video out there from DTV stating that SWM was designed to be run on existing cable wiring in residences and apartment buildings.
I also use a green DTV splitter and run raw sat sig to my rear tv with another sat box back there.
OP has DISH, not DirecTV, so don't be using no green splitters on that sat dish line.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 27, 2025
