_tpc_'s avatar
_tpc_
How to set up portable satellite dish...
Ok so here is the story. Have a TT, 2014 Keystone passport. It has the crank up regular style winegard antenna with the small wall panel that has the booster, and the cable comes from this panel into the tv. I know when not using cable the booster is on, when using cable the booster is off.
The satellite thing will be dish network with the latest box (bundle kit). Hasn't arrived yet. I'm guessing the box will have HDMI out to the tv.
Here is the dilemma. I would like to keep the regular antenna intact in case of some reason I would want to use it over the dish. Since most parks (at least here in michigan) cable has been regulated to the need of the digital converter box in order to get any real stations, much like our homes here are, the cable input on the oustide of the trailer is relatively useless.
With have the dish setup I cannot see ever using the cable anyways. So what would be the best way to get the sat line into the trailer from outside, without running the cable in through a window or door? Can I use the cable input somehow and rewire it?Should I start dropping the chloroplast and drilling holes into the trailer from the outside to wire it in?
I'd like to be able to attach the dish cable to the back of the trailer somehow. Or maybe I can come up through the bottom someway and attached a fitting to the frame?
Any thoughts on this?
  • Keep your cable hook up. When you are on the road and stop at an RV park for 1 night you can plug into cable and won't have to set up your satellite. Unless your satellite is automatic on the roof, then cable is not an issue.
  • I also have dish and run two receivers off of it, I did as above stated and just added a plate to the outside and ran it under in the bay area and then up to the bedroom with another plate and marked it SAT-2. Very easy to do and love DISH with the $7 a month my RV...
    You can get the cable at walmart and the plates.
  • Best? Run a dedicated RG6 coax cable from somewhere with easy access to outside to behind the TV. A standard deco wall plate will make for a neat finished product inside. Standard coax cabling from the factory often has splitters hidden in the walls which are detrimental for sat signals.
    I was able to snake my cables through the basement to a place where by drilling a couple of small holes I got the cable into a dead space on the wall behind the TV. Pulled the cable out, attached a connector, screwed it to the deco plate and screwed that over the hole. In a front compartment I attached a wall adapter. Then it is a simple matter of feeding the coax from the dish to the mount.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
