- RVJimofOregonExplorerTHANKS for all the good input. I should of used search but didn't and glad as I found out about PNG files. Inside of MS Publisher found out I can change file type.
Thanks again.
Jim - strollinExplorerThe reason why PDF is not a good format for a logo is because a PDF is a document format (PDF - Portable Document Format) to be used for whole documents while a logo is simply an image which is a piece of a document. Save the logo in an image format such as png or jpg. Once you create a document (which may include your logo), save the document as a PDF so that it can be read on many different platforms.
- 1492ModeratorPDF is not a good format for use as a logo in a Word document. Save the logo in PNG format instead. Then just drag and drop into your Word document at the cursor position.
- wa8yxmExplorer IIIGoogle PDF to WORD there are converters
Or go to giveawayoftheday dot com
http://giveawayoftheday.com/
From time to time they offer PDF converters for free. - jcpainterExplorerFor a clean look. Open up your .pub in Publisher, save it as an image file . . . perhaps a .png for a transparent background and then insert the .png into Word.
- hbillsmithExplorerUse the clipping tool. Open the pdf. Use clipping tool to grab your logo and the save that as a jpg file. From there you can insert into word.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,805 PostsLatest Activity: Aug 02, 2025
