havasu's avatar
havasu
I am loving this "Millenicom"
We have been used to Cable Internet in the stick house and so moving into the RV as fulltimers but still working Internet based jobs, I found that we were getting very restricted Internet services from campground WiFi. Especially as more and more of the stuff that we use is now "cloud based" and relies upon having a healthy chunk of bandwidth.
Initially I set up the AT&T phone as a hotspot and applaude AT&T on their excellent coverage and speed - but 4GB just isn't enough for what we need.
Campgrounds vary significantly and all of them become almost unusable after 4pm when everyone needs to get online.
I then looked at Millenicom and they have a 20GB package with a hotspot on Verizon and I have heard good things about Verizon services. However, after monitoring a day's worth of use, I realized that we need around 1GB a day for everything that we do work wise.
So after some investigation, I purchased a Sprint Tri-Fi hotspot from eBay and signed up with the Millenicom BYOD (Bring Your Own Device) which operates on the Sprint network and has 'unlimited' bandwidth for $70 a month. Of course it isn't unlimited at all but capped at 50GB a month which is more than adequate for us.
I was worried about Sprint as they don't have a good reputation and my cell phone is on Sprint and suffers terribly - but the Tri Fi can switch between 3G - 4G - 4G WiMax and 4G LTE and so regardless of where we are, we can get some sort of service. In Memphis we have 4G LTE and in Nashville we have found that although they are rolling out LTE, the WiMax signal is stronger and giving us 4MBps speeds.
A 50GB data plan with AT&T or Verizon would cost over $350 a month so bravo Millenicom!
  • It'll likely take years before Sprint will have its 4LTE network setup nationwide. They bought out Clear, pending FCC approval, so own 100% using their 4G WiMax in the intern until they can build out or replace Clear's towers with 4G LTE.
    Clear does offer unlimited 4G WiMax for $34.99-$49.99 a month depending on download speed. AFAIK, it's still unlimited as I typically use about 16-19G 4G mobile data per month, with up to 50G a month at full speed with no bandwidth throttling.
  • Millenicom has my vote. Outstanding customer service, too.
    When we are driving down the road, I use a Wilson Cradle to keep the signal coming in strong to our MiFi. If you don't use one yet...look into it. The 3G Store will steer you to the one that works on the Sprint network. (You can use it to boost your cell phone's reception as well. It does not even have to be laid on top of it. When I put my cell phone next to the wilson cradle, I have seen the signal bars go from barely 1 to 3 bars sometimes. It really works well.)
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,805 PostsLatest Activity: Oct 27, 2025
