vegasken34's avatar
vegasken34
Ipad booster
I have a booster for the cpu that picks up wifi great. Is there a way I can pick up wifi on the Ipad thru this booster or do iI need one just for the pad?
  • What your talking about is a wifi booster. If you think about it RV's are sheathed in aluminum and metal all of which block rf signals. So an external antenna is the key. I bought a hawkings smart repeater router and connected it to a hawkings wifi antennae on the roof. As long as the CG has a good wifi setup, I have full signal.
  • if you are talking about a USB Wifi stick for PC's ?
    does the iPad have a full size USB port ?
    if so try it..
    But i really doubt it will work
    for in the RV or house you can get a WIFI repeater/amplifier that will pick up an access point signal and increase relay/increase it
    i don't know of anything that plugs into the ipad for on the go portable use to increase signal
    might try some ipad forums to look for such info
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 27, 2025
