docj wrote:
There is a huge amount of misinformation in this thread. You don't have anything wrong with your iPad and neither is there anything "wrong" with the router.
The wifi problem being experienced by iPad running iOS6 results from Apple having implemented a protocol known as WMM....
You may be right about that, except that I believe Apple has implemented WMM since at least iOS4.x. It's not new to iOS6. Or did Apple change something with the way they implement WMM in iOS6? Notwithstanding, if WMM is the issue in this case, then not sure how deleting/creating a new WiFi profile if WMM is not enabled in the Park's router in the first place, would not be a moot point?
I would have doubts that WMM is the only iPad WiFi related issue. Considering some owners pointing to WPA2/AES specific connection problems, but working fine with other encryption protocols. And that Apple has apparently been replacing customers mobile devices who complain about this connection issue. I don't see why they would do this if it was a router based issue, since a replacement would experience the same problems? :h
