obiwancanoli's avatar
obiwancanoli
Is there a more accurate way to measure fluid levels?
I'm not a big fan of the meters in my MH that show fresh, gray and black tank levels... They're hardly accurate, but I wondered if there's a better way... ?
  • there are better sensor systems, but they aren't inexpensive. Seelevel system is what I have and it is very reliable. Garnet systems.
    There is another external sensor system similar to the Seelevel as well.
    Seelevel is easy to install and uses the existing wiring system, but can't be completely calibrated to acount for odd tank shapes.
    the other system can be calibrated for odd tank shapes but is harder to install and IIRC doesn't use the existing tank sensor wiring.
