2chiefsRus's avatar
2chiefsRus
Jetpack vs MiFi vs Hotspot
Is there any speed advantage to buying a Jetpack vs just using your smart phone as a hotspot? Here's the background to the question. Years ago we had a MiFi that we used to access the internet back when we had flip phones. Fast forward a few years, we buy smart phones and when the hotspot died, we just used the smart phones as hot spots. Now it is time to replace the aging smart phones (Samsung S-4 Minis) and I am wondering if we should also get a jetpack too or just keep using the smart phones hot spot feature. Do the jetpacks provide better coverage or speed, etc.? Your thoughts? Thank you.
  • We stopped with a dedicated internet device a couple iterations ago.
    We stream all the time and it's our primary internet source.
    Yeah, you need to keep it plugged in if using for long but that applies to phone or dedicated internet device.
    In real world use, we couldn't tell the difference so no need to buy a separate device and more importantly separate monthly plan.
  • thank you everyone for taking the time to reply. appreciate the information.
  • It is very rarely the hardware that determines the throughput or bandwidth you’ll receive today. With any reasonably modern modem, be it phone or a dedicated hotspot, the limitation will be how much speed you are allocated by the carrier tower. Which is a function of what plan you have (priority), and how many other users are competing for the resource (congestion).
    And then there’s throttling, which is a hard speed limit built into the fine print on many plans.
    I respectfully, but strongly, disagree. With plans and tower congestion being equal, hardware makes a HUGE difference. Watch the video HERE for live comparison testing results on hotspots at the same location, same plan, same time of day. Phones are the same.
  • We typically get better speeds on our dedicated AT&T and Verizon hotspots than we do using the WiFi hotspot feature on our LG Stylo 3 phones on Tracfone/Verizon. We also like having the separate AT&T hotspot so we can make VOIP calls from our phones in weak Verizon areas. Both of our hotspots are on grandfathered unlimited data plans subject only to network management on heavily congested towers, something we've rarely noticed.
    Interesting information in the link. My Pixel 3 phone has the Qualcomm® Snapdragon™ X20 LTE modem that is a Cat 18 LTE modem so it should have the equivalent capability of the Verizon Jetpack® MiFi® 8800L in the video. Good to know.
  • We just got our first RV(Coleman 2515RL) and we're actually in our first RV park for the weekend. I got here on Friday around noon expecting to work for the rest of the day. The internet at the part was reasonable ($5 for three days) but the speed is horrific (1 to 2 Mbps). Nothing that I can work on. I want to travel and work from the RV during the week. I am thinking of the Verizon 8800 Jetpack, but the reviews online are abysmal. Is anyone on these forums using one? How are they working for you? I few people in this thread have referenced them...they seem to like them. I'm just wondering if there are other opinions about them on this forum.
    If you are planning on working from your RV, look at a MOFI 4500 with an external Yagi directional antenna. You insert your phone's SIM card regardless as to whether Verizon, AT&T, or whatever, and the increase is pretty crazy. It seems to be able to pull a signal no matter how weak and turn it into a speed as if you are in the center of a city. I have tried jetpacks, MiFi, signal enhancers; this is the way to go, by far.
    When the 8800L first came out, and for many months after that, some units had a big problem with random reboots. The manufacturer has now provided Verizon with a system update that most people report totally fixed the problem.
    Just do a "check for updates" on the hotspot and the new software/firmware update will load. Easy peasy.
