d3500ram's avatar
d3500ram
Explorer III
Sep 22, 2018
Laptop cleaning & maintainance ...?
I want to keep the new laptop purchase in clean and good order.
The compressed air does only so much and am considering a dedicated mini vacuum along with a gentle brush. There are an awful lot of selections from which to choose.
What do y'all use for a computer vac?
I am also considering getting the rubber plugs that cover up the chassis slots when not in use (but am almost certain those will eventually get lost over time)
Any other good recommendations?
  • Not really a brand hound myself, but I'd look for any small vac that has a black hose AND has both a suck and blow connection for the hose. That hose will often have been made with carbon black to color it and carbon is good for dissipating static. You're looking for a vacuum that has the marketing blerb "static dissipating" or "low static" or some such.
    Then when I do a laptop cleanout, if it's low humidity, I'll spay a fine mist of distilled water (an RV'er should carry some already for the batteries) about 12" over the laptop.
    Then I'll use both the suction & blower to get as much dust and dirt out as possible. Sometimes I'll remove the CPU and really go to town on the heat sink with alcohol and a toothbrush.
    The whole idea is to get the dust and dirt off of the heat sinks and fan blades and sometimes, with some designs of laptops, you're going to have to open the case to do a good job. And that sometimes means taking it to a computer shop.
  • Other than in a work place environment, I've never had the need to worry about such a thing..
    My users in my corporate environment go thru more keyboards and mice than I can count... :)
    Home use, unless you are eating cookies and spilling Coke, coffee, water, etc on your laptop, you should be fine with just compressed air at the most to get rid of the dust at most..
    Good luck!
    Mitch
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
