Mountain_Mama's avatar
Jun 11, 2015
laptop sleeping question
I want to update my GPS maps. It usually takes such a long period of time I close the lid & it goes to sleep. Does this stop or just slow down the updating process? I really don't completely understand "sleeping". Even if I don't close the top it eventually goes to sleep anyway.
Suggestions on this & whist is best to do??
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Depends on your LID CLOSED settings (some laptops)
    If lid closed simply turns off display YES
    If it puts computer to sleep NO
  • Another solution is to download and use this small program. It will keep your computer awake during long downloads by simulating a key stroke every 59 seconds. You can turn the program on or off as needed.
    Caffeine....HERE
  • Naio wrote:
    Is it a windows laptop?
    If so, you can set it to not sleep. At the bottom right corner of your screen, right click on the little pic of a battery. Choose 'power options', then look at the left hand column.
    If you like the sleep feature, reset it after doing your update.
    I usually do this about once a week so all my updates can get caught up. Then switch back to more power-saving settings if you need to conserve battery.
  • after you click the power options
    left hand collumm
    pick choose what happens when i close lid, then click the choice "nothing"
    also
    then click change display options
    you will be presented with timer choices .. for battery operation and plugged in operation
    when done click save then exit/close window
    on mine for plugged in i set turn off display at 30 minutes
    and shut down PC at never
    so when i go off to bed or walk away from it, it still keeps doing whatever task i left running, either downloading some file or processing some video
  • Naio's avatar
    Naio
    Explorer II
    It certainly won't update it when asleep, or off-line. I'd push: INSTALL/UPDATE, then walk away from it, but I wouldn't put it to sleep/re-start, or, OFF.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Aug 31, 2025
