TenOC
Apr 06, 2017Nomad
MrWizard wrote:
I don't know the specifics
But members over on HoFo are doing it this way via USB network cable
There is a micro USB port on the side of the Mobley
Has a little rubber covert over it, same texture as the case body
Plug in to that, and plug the other standard USB end into the back of router, If it has a USB port
In many instances the router will find the Mobley and auto configure is connection
You connect to the router Wi-Fi
I think there was a picture posted over in the main thread, I know I saw pictures in the Howard forums thread (HoFo)
After breaking a fingernail, I found the Mobley USB connection. The problem is the Liksys WRT54 router does NOT have a USB connection.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
